Ricky12345's avatar
Ricky12345
Follower
Dec 16, 2016
Netgear Genie App for Android - Login Remote access
Hi, I am unable to login remotely to my Genie app (outside of router/wifi coverage). Model: AC1900 Nighthawk. The desktop App does not have an option to Login as REMOTE ACCESS. Refer screen shot. Please help. Thanks.
  • DexterJB's avatar
    DexterJB
    Jan 12, 2017
    Hi @donaldlund2010,
    If you are in the process of setting up remote login via NETGEAR Genie for Android then the link below may help you out.
    http://kb.netgear.com/26846
    Make sure that the Android device is connected to your own network. You can reset the router if the password issue persists.
    Dexter
    Community Team
    • donaldlund2010's avatar
      donaldlund2010
      The link you provided if for desktop. I need android. There is no option for login as on android genie app. Default login is admin and you can't change it. I had password as passwotrd and says is wrong. Changed password and tried again, still dsdsays wrong. Please help
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi @donaldlund2010,
        Dexter
        Community Team
