ChipMcK's avatar
ChipMcK
Follower
Nov 15, 2015
NetGear Genie for Mac latest version
Trying to downlad latest version of Genie for Mac.
not interested in the iPhone version
not interested in iPad version
I am seeking the version for OS X.
the site http://www.netgear.com/home/discover/apps/genie.aspx does NOT have the OS X version - all I can get the the manual
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi ChipMcK,
    This is most likely an issue with the page redirecting to another link. I will have this reported to the devs so that it can be corrected. Alternatively, you may download it from the product page of your device or you may use the download link below.
    Product page option:
    1. Open http://downloadcenter.netgear.com/
    2. Type the model number of your device (i.e. R7000) then select the device on the drop down.
    3. Under the list of Firmware/Software, select the option "More results..."
    4. Select NETGEAR Genie App (Mac)
    Download link option:
    http://files.netgear-support.com/go/?a=d&i=MnVea8xitH
    Dexter
    Community Team
    • ChipMcK3's avatar
      ChipMcK3
      Thank you for info.
      Search on internet yeilded as Releases: 2.4.15, 2.5.1.1
      But the downloads from sites always gave 2.4.10 level product
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi ChipMcK3,
        If you have downloaded and installed an older version, you will be prompted to update the app once an update is available. It will show an indicator on the top portion of the NETGEAR Genie window.
        Dexter
        Community Team
