llalonde
Oct 31, 2015Initiate
Netgear Genie unusable on Mac
Hello Folks, Netgear genie is unstable on a Mac (El Capitan). I cannot quit the application once I've finished using it. I have to do a 'Force Quit' to kill the application. Anyone have...
DexterJB
Mar 09, 2017NETGEAR Moderator
Hi FRANKORFANELLO,
1. What macOS version are you using?
2. What version of Genie do you have installed?
3. Please try uninstalling and re-installing the app.
Dexter
Community Team
FRANKORFANELLO
Mar 10, 2017Aspirant
Dexter,
Thanks for the reply.
I am running OS X 10.12.3 Sierra
The Genie app is 2.4.22 When I go to check for updates it tells me I'm current.
I have uninstalled it, deleted the app redownladed and reinstalled and still have teh same issue.
Thanks fo ryour help.
- DexterJBMar 13, 2017NETGEAR Moderator
Hi FRANKORFANELLO,
There is another thread linked below with some steps suggested. Please check it and see if the work around works for you.
https://community.netgear.com/t5/Genie/Netgear-Genie-won-t-quit-on-Mac-OS-X/td-p/1034944
Dexter
Community Team
- llalondeMar 14, 2017Initiate
The fix proposed by the other thread (renaming libGeniePlugin_MyMedia.dylib) worked for me...
The Netgear support team worked actively for quite some time on this case. They were very pro-active in trying to find a solution. However, they were not able to reproduce the problem. They suggested I re-install my Mac from scratch...
I don't use the 'Media' part of the router... so I didn't mind disabling the above mentioned plugin. It solved my problem.
- FRANKORFANELLOMar 14, 2017Aspirant
llalonde, thanks for the reply.
So the problem iappears to be in the "libGeniePlugin_MyMedia.dylib" module, and the solution is to simply disable that function?
I guess I'll try that and report back, until Netgear fixes the problem.
As a follow up, this worked for me too.
- DexterJBMar 14, 2017NETGEAR Moderator
Hi all,
Thank you for the confirmation. We are continuously looking into this.
Dexter
Community Team
- eleutheroApr 23, 2017Aspirant
I have the problem as well, running version 2.4.22, installed yesterday. After telling it to quit and then assuming it would (despite siginficant evidence to the contrary yesterday), I discovered it running away with my CPU several minutes later. This runaway process also seems to somehow be using a large amount of bandwidth at the same time. It appears to have been almost two years since this problem first showed up (and disabling a feature on the router isn't an answer).
