- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Genie won't quit on Mac OS X
- Mark as New
- Bookmark
- Subscribe
- Permalink
Unlike some people here, I had no trouble downbloading and installing Netgear Genie on my Mac system, first on an old iMac running OS X v10.6.8 and now on my new iMac running 10.11.2. Unfortunately the program's interface is terribly buggy. The worst problem is that once started, it refuses to Quit. I have to Force Quit it, which is not a good thing to have to do with any application. Other aspects of the interface suggest it's just an automated port of a program from some other operating system, or perhaps a Java app -- neither of which is a good thing.
It works alright when it's running (I guess) but I'm very disappointed in the quality of the app. It needs a good solid rewrite and upgrade, real soon now.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All:
Here's what (sorta) worked for me, based on escalation at Netgear to "Bianca" who seemed to really know how to troubleshoot. The fix that worked for me was to open the Genie package and to add a leading "1" to the component "libGeniePlugin_MyMedia.dylib", making it "1libGeniePlugin_MyMedia.dylib". This disables the Media Center features of the router, which I don't use anyway. Now, CPU usage is at about 10% (still too high for a "monitor", but tolerable), and I no longer have to force quit.
Jonathan
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Genie won't quit on Mac OS X
Hi @RoboGenie,
Thank you for your feedback. Rest assured, we are always working on improving the features and user experience for the program.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm experiencing the same thing on my late 2009 iMac running OS 10.11.2. Netscape Genie won't quit in the normal fashion. I have to force quit it every time.
On the plus side, I really like the graphical display of attached devices and the ability to add plain-English names. It's far more user-friendly than the list of attached devices in the router's configuration settings.
Jeff Frankel
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @jmfrankel,
Thank your feedback as well on this. This is noted and will certainly be looked at.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same problem, the app won't quit. Displays the "are you sure" message then the spinning ball of death goes forever. Only a force quit works. Has been this way for over 6 months now, both on older versions of mac os x and the newer El Capitan.
When will this be fixed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Genie-beach,
We currently do not have an ETA for the next update. Rest assured, we are working on improving the app.
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having the same issue here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have the same issue, running the latest Genie (Version 2.4.12) on MacBook Pro (13-inch, Mid 2012) with El Capitan 10.11.4 (15E65) - it just stuck on Quit. Have Netgear R8000 router if it helps.
Below is what reported in console log:
4/15/16 01:17:45.000 kernel[0]: process NETGEARGenie[2789] thread 128206 caught burning CPU! It used more than 50% CPU (Actual recent usage: 71%) over 180 seconds. thread lifetime cpu usage 90.091226 seconds, (86.067295 user, 4.023931 system) ledger info: balance: 90002656539 credit: 90002656539 debit: 0 limit: 90000000000 (50%) period: 180000000000 time since last refill (ns): 125908595734
4/15/16 01:17:45.818 ReportCrash[3954]: Invoking spindump for pid=2789 thread=128206 percent_cpu=71 duration=127 because of excessive cpu utilization
4/15/16 01:17:46.800 spindump[378]: Saved cpu_resource.diag report for NETGEARGenie version ??? (???) to /Library/Logs/DiagnosticReports/NETGEARGenie_2016-04-15-011746_XXXXXX.cpu_resource.diag
4/15/16 01:28:32.055 spindump[378]: Saved hang report for NETGEARGenie version ??? (???) to /Library/Logs/DiagnosticReports/NETGEARGenie_2016-04-15-012832_XXXXXX.hang
- Mark as New
- Bookmark
- Subscribe
- Permalink
Having the same issue. Before purchasing the Nighthawk 7000 I'd read of the Netgear Genie problem, so I'm not too surprised to encounter it. But still disappointed.
This is an issue that Netgear has clearly known about for some time. The application does not take "quit" for an answer under OS X. El Capitán in my case.
I'm sure you can do better!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have to force quit Netgeargenie also.
MacOS 10.11.5
R7900
Firmware V 1.0.1.4
NETGEARGenie V 2.4.12
Also uses 1/4 of CPU power when running.
Should have been fixed by now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
There is absolutely no reason - except for a prettier interface - to keep Genie.
Entering routerlogin.net into your browser to get same functionality without sucking up CPU power or otherwise dragging down performance.
In my emails on this same subject with Netgear tech support in May and June, they provided a multi-step "debug" fix doc as a work around to stop Genie from hanging when quitting under OS X.
I cannot locate the doc at the moment, sorry, but if you ask I'm sure they can supply it. However, I recommend deleting Genie and doing the routerlogin.net thing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I do like the interface, but I've concluded that Netgear has decided to stop supporting Genie for the Mac. I've traced the problem back at least two years, and all of the "rest assured" messages from the company rep posted to this thread, on such a fundamental problem, seem hollow.
I'm running Genie 2.4.12 on the latest MacOS (just updated to 10.11.6) and it's still using enormous amounts of CPU and fails to quit properly. I've reinstalled numerous times, and also watched the tech support death spiral as I tried to get the issue resolved before my free support ran out. They actually got to the point of suggesting faulty hardware and asking me to do without for three weeks while they figured out that their hardware isn't actually running the faulty software. No thanks. I just won't consider Netgear when it comes time to upgrade, and will definitely pay more for decent (free) tech support and actual programmers that work for the company in question. If anyone knows of such a company other than Apple, let me know, and I'll go there first!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Agreed. However, as I think I scribbled elsewhere on this thread or a related one, aside from a prettier interface, Genie offers nothing that typing routerlogin.net into your browser window doesn't do.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Acknowledged, and yes, that's how I'm managing the router now. The browser interface is clunky in other ways that I won't go into, but it'll do until I upgrade my hardware. It's more of an issue of a company continuing to ship a product with unsupported software that takes over the computer, commercial malware, if you will. That's not cool.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is noted that you were working on the problem of having to force quit out of Network Genie as of last January, yet the problerm still persists. When is this issue going to be fixed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
All:
Jonathan
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for posting that. I received similar instructions several months ago and was looking to post it when another frustrated Mac user posted to this string. Personally, I don't find the "added value" of Genie - as opposed to querying the router directly from the browser - not worth the trouble.
- Mark as New
- Bookmark
- Subscribe
- Permalink
whoops...one too many negatives in there, but you get my point.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sad day when you spend $170 on a router and the company studiously ignors a problem that they have been aware of for some time. I guess there is not much competition in the router industry 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the workaround!
- Mark as New
- Bookmark
- Subscribe
- Permalink
That did the magic for me. Thanks a ton !!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you! This workaround should be at the top of the comments. Had I not went to the next page i wouldn't have found it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Workaround worked for me, thank you.
