dieckman001
Oct 02, 2017Follower
Netgear Genie upgrade errors
Netgear Genie is telling me I have an upgrade available on the program. Once i download and try to install I keep getting the "following disk images couldn't be opened" message from my Apple Macbook...
Retired_Member
Oct 10, 2017It looks like the installer will only work if your Mac is running the latest macOS: High Sierra. I opened it using 7-Zip on Windows and it shows that the file system inside the DMG file is in APFS format which doesn't open on any older version of macOS.
This is contrary to the upgrade message saying 'Recommended minimum Mac OS version is 10.7.5'.Upgrade Description
Failure to Open DMG File
vinlab81
Oct 16, 2017Initiate
My OS is 10.10.5 and I've this error too.
I can't even open it with 7zip.
