Zonker
Oct 16, 2016Apprentice
Netgear Genie v. 2.4.3 for iOS 10
Having a few problems with the Network Map. 1) The iOS app does not see the saved changes made on the Netgear R7800 web interface. So its like starting from scratch when you use the iOS mobile a...
DexterJB
Oct 19, 2016NETGEAR Moderator
Hi Zonker,
1. This is a limitation of the app since the changes (name, device type, etc.) are saved on the device only and is not synced up to the web UI and/or any other device in the network.
2. Let me check on this.
Dexter
Community Team
Zonker
Oct 19, 2016Apprentice
"1. This is a limitation of the app since the changes (name, device type, etc.) are saved on the device only"
It does not even save them on the device. Each time you open the network map it defaults to the same name, device type, etc.. as before changes were made. Looks like a bug
Z
