velocci's avatar
velocci
Novice
Jan 12, 2012
Netgear Genie
Hi all, I installed the netgear genie app. I notice in the Internet tab, if you look at the bottom you see a slider that goes upto 20Mbps and button for "High Traffic Threshold. What are these for exactly? is it to limit the speed of transfers when there is high network transfer? if I want the maximum transfer speed, should I have this box unchecked?
  • I didn't notice any difference in the transfer rate when I played around with that feature. Is there a manual for this software?
    • NeedHelpToo's avatar
      NeedHelpToo
      FYI the manual doesn't tell you what the "high threshold" checkbox does.... does anyone know?
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi NeedHelpToo,
        The "High Traffic Threshold" check box will enable the NETGEAR Genie to monitor and notify you whenever it reaches the slider value of Internet traffic that you have set for the upload and/or download.
        Dexter
        Community Team
