sidkat's avatar
sidkat
NEtgear NightHawk App
Since the update from 2/23/23 when I re-downloaded my NightHawk app the only thing it shows is my CAX30 is connected locally. I can't check my internet speed, metered connections or what devices are at 2.4 or 5Gh. Is there someway to fix this?
  • michaelkenward's avatar
    michaelkenward
    Are you talking about Anywhere Access?
    Which version of the Nighthawk App? iOS? Android?
  • Version 2.24.0.44 on iOS says Anywhere Access. It just says connected locally and can’t use any features of the app. I honestly don’t recall it saying Anytine Access before. I used to just hit the app icon and all the features would show.
  • FURRYe38's avatar
    If v2.x please use a wired PC and web browser to downgrade the modem to v1.4x FW
