Peavine's avatar
Peavine
Follower
Feb 28, 2026
New Cable Modem
I have obtained a new cable modem to replace an older one. What is the best way to set up the Netgear router for WiFi after I activate the new cable modem connected directly to my PC via the ethernet cable?
  • StephenB's avatar
    If you already had the router running with the old modem, then all you need to do is connect the cable modem ethernet to the router WAN port.
  • FURRYe38's avatar
    Power off both NG router and cable modem for 30 seconds, then power ON the cable modem. Give about 1 minute then power ON the NG router.
    Review the installation guides for setting up a router.
    Set up with the Nighthawk app or with a PC and web browser.
