mikalias
Jan 06, 2017Aspirant
new router say's inter 'Not Connect' in red but everything works
When I tried to setup my router I tried to use the net genie but it alway fails at one point so I set it up manual and it worked but now when I log in under the home column and the Internet tab it says 'Not connected' in red but all the other tabs show everything is working. I donwload the netgear genie and it show the same tab for internet and it is 'Status good'. Whats going on why doesn't the home column when you log onto the router show no internet yet everything works and the downloaded netgear genie show every 'Statu good' and everything works on the internet and Lan, how weird is that and can it be fixed.
Mik
- DexterJBNETGEAR Moderator
Hi mikalias,
1. Are you referring to the Internet Status when viewing the router UI via a browser?
2. Does it show an IP address on the Internet port box under Advanced > Home?
3. Please make sure that your devices are connected to the correct network (both wired and wireless).
Dexter
Community Team
- mikaliasAspirant
No, I'm talking about the router when you log in as admin. The home tab at the top and it show a little world icon and below it, it says 'NOT CONNECTED' but I am connected because all the other tabs are green and my internet work fine and yes it shows an IP port address under advanced. The seperate app that runs outside the router 'Netgear Genie' show's the same little icon of the wold but it is green and says internet is connected but the router does'nt. All my wifi works fine too. really odd.
Mike
- Marcus305Aspirant
I am having the exact same issue as Mike.
Dexter - yes, I think we are both talking about the router user interface (UI) that we access through our browsers (by going to www.routerlogin.net). The Genie app shows a good internet connection but the browser UI says "Not Connected" for the Internet status. I was also not able to use the wizard to initially set up my router because the Genie web UI found there to be no internet connection. Nevertheless, I was able to access the internet on my wired and wireless devices, so the router seems to be functioning okay.
I believe there is a problem with the UI that is accessed through a browser that is causing this false error (as well as preventing the use of the wizard to set up the router).
