qunasfoma
Jul 17, 2023Follower
Nighthawk AC1900 connected devices not visible
Hey guys hoping someone can chime in. I have an issue with seeing my devices on the nighthawk app. Currently have 10 connected but only 2 show up. Some backstory. . .I had optimum internet and I wa...
michaelkenward
Jul 17, 2023Guru - Experienced User
Which Netgear device(s) do you own?
AC1900 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
qunasfoma wrote:
I blocked those 8 devices in order to not keep unplugging set devices.
Blocked where and how?
What has that got to do with "unplugging set devices"?
It might help if you explained what you were trying to do.
Blocking severs the connection and has nothing to do with unplugging things.
Anyway to get these devices to show up again on the app ?
Do they connect to the network?
schumaku
Jul 20, 2023Guru - Experienced User
Ignore, one more type of SEO Spam and Scam 8n the signature...
- michaelkenwardJul 21, 2023Guru - Experienced User
schumaku wrote:
Ignore, one more type of SEO Spam and Scam 8n the signature...Edited after the event?
The original message was from a different user and with a time stamp a day earlier.
Something strange is going on here.
- schumakuJul 21, 2023Guru - Experienced User
michaelkenward wrote:
Nope. Just the profile was updated, including the signature. Often a repeated scheme by SEO "specialists"....
michaelkenward wrote:The original message was from a different user and with a time stamp a day earlier.
Time stamp is updated with the new login. Different user is difficult, different username probably - have screenshots at hand?
- michaelkenwardJul 22, 2023Guru - Experienced User
The change was visible in the RSS scraper (Website Watcher) that I use.
Unfortunately, as I have it set up Website Watcher doesn't remember things that long. Not something that I usually need to worry about.
Looks like another defect, one of many, in the community software (from Lithium?) that Netgear uses.
Same result. It "edits", as in changes, the post.
Seems to be a lot of effort for very little result.
