smerdonw
Mar 25, 2017Aspirant
Nighthawk AC1900 Model R7000 Won't connect to internet
I just purchased a Netgear R9000 Nighthawk X10 and successfully set it up and connected to the Internet. However, in Genie (web version) on the Basic tab under Home the Internet block still says "ERR...
michaelkenward
Mar 26, 2017Guru - Experienced User
smerdonw wrote:I just purchased a Netgear R9000 Nighthawk X10 ...
That's a router. And the modem is?
You need to introduce the two properly before they will work together.
If no one had got an R9000 to work, you would know about it.
