D1876
Jun 12, 2021Aspirant
Nighthawk App and C6250
The Nightgear app on my iPhone keeps telling me the firmware for the c6250 is out of date. But the routerlogin.net menus don't have an option for updating firmare. That a normal feature of the using ...
michaelkenward
Jun 13, 2021Guru - Experienced User
It is a bug an the app. Netgear claims that it is on the case. Has been for some months.
The message actually makes no sense. You have the C6250. That is a cable modem/router. Neither you nor Netgear can change it.
Only the ISP can do that.
If your firmware is outdated, you cannot manually upgrade your cable modem’s or modem router’s firmware. You must contact your Internet service provider (ISP) to upgrade your firmware.
So what is the point of an app throwing up that message?
- D1876Jun 15, 2021Aspirant
Thank you for confirming the madness ... it is ridiculous the app continues to give the message. It's also recommended to use Nighthawk to control the device.
Thanks again!
- michaelkenwardJun 15, 2021Guru - Experienced User
Here is the longest running discussion of this insanity.
Nighthawk app same "firmware not updated" when it ... - NETGEAR Communities
I'll have the info forwarded to our App Team to look into the Nighthawk app and request for any changes needed.Four months and counting.
Experienced users avoid using apps for local control. A browser does more.
The apps are fine if you need Anywhere (Remote) Access.
