smoke_showin
Oct 20, 2022Tutor
nighthawk app anywhere access failure
What is going on with Anywhere Access? I have multiple routers that was all working fine a couple weeks ago. I can’t enable, disable, or see my routers anymore. All it says is something went wrong. Pl...
- Oct 25, 2022
smoke_showin wrote:
It has to be the app.Which is something that you have not told us about in this one-way "conversation".
michaelkenward
Oct 21, 2022Guru - Experienced User
What routers are they? What firmware is on them?
What mobile device are you using for Anywhere Access? Android? iOS?
Did you enable Anywhere Access on the browser graphical user interface (GUI)?
xTEKNIKLx
Oct 22, 2022Aspirant
Same. Mine hasn't been working for about a week and a half or more.
Can't enable or disable anywhere access using the app. Just gives a "Something went wrong. Try again" message. Repeatedly.
Tried resetting the router and doing a fresh setup as well.
Worked perfectly fine up until now.
Rax200
Firmware 1.0.10.140_1.0.79
Rax200
