afitz485
Aug 07, 2022Tutor
nighthawk app can't modify settings when nighthawk cax80 modem is offline
My cable modem (with wifi router) CAX80 can connect to the internet over the coaxial cable. The Xfinity tech came over and set up the connection. I decided to take the modem offline in order to c...
- Aug 07, 2022
Factory reset the modem and setup from scratch using a ethernet connected PC and web browser.
Aug 07, 2022Guru - Experienced User
