mharrod's avatar
mharrod
Nighthawk app device manager
I have an R9000 that I use the Nighthawk app to manager. When you go to the Device Manager, it shows the same connections multiple times. Been that was for the last several app and router software/firmware versions. Any help appreciated. Firmware is 1.0.5.14 and app version is 2.5.0.47. I attached a pic of what the device manager looks like.
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello mharrod,
    May you try reinstalling the Nighthawk app and factory resetting the router. A successful factory reset on the router will prompt you to run through the setup assistant again.
    Christian
    • mharrod's avatar
      mharrod
      I’ve tried that several times. I also have two Netgear extenders which I forgot to add to the original post. I have reset them both as well.
        Christian_R
        Hi mharrod,
        Thanks for confirming. I'd like for our support team to reach out to you for further assistance. If you wish to be contacted, please send me a private message with your contact info.
        Christian
