mal_t's avatar
mal_t
Nighthawk App (formerly up)
Hi, I just downloaded the Nighthawk app on my phone. Went to log in and it aks for an account. I tried logging in with my "My Netgear" account, but doesn't work. Do I need to create another account for this??
  • Oops ! maybe I should have added that the "My Netgear" account let me log in here.
  • michaelkenward's avatar
    michaelkenward
    MyNetgear now lets you into everything Netgear. In the past you could use separate credentials to get into here. I still do.
    Here at least, the Nighthawk app uses the same details as MyNetgear
    • schumaku's avatar
      schumaku
      As per the Which routers support the NETGEAR Nighthawk app? the tagged D7000|Nighthawk AC1900 VDSL/ADSL Modem Router is not supported by the Nighthawk App.
      In general, the initial login - while connected to the (supported) router [W]LAN - is the router local admin account:
