LSJR3
Apr 01, 2026Follower
Nighthawk app jumble up
Hello. Does anyone have an error in the Nighthawk app that makes the login area impossible to select anything but "forgot password"? I tried to attach a screenshot that I had taken but every time I h...
schumaku
Apr 02, 2026Guru - Experienced User
LSJR3 wrote:... the Nighthawk app that makes the login area impossible to select anything but "forgot password"?
Uninstalling and re-installing the Nighthawk App does not change anything?
On Android, start with a [Clear Cache} close and re-open the App. If this alone does not cure, try [Clear storage] and re-open. I guess you have to re-authenticate on the Netgear cloud.
