nldl8485's avatar
Feb 02, 2021
Nighthawk app missing remote management, speed test, and blank device names
I am running Nighthawk app version 2.8.1.0 (this version was loaded from the apple app store tonight).  I do not have speed test functionality, I cannot enable remote management because it does not exist in my app, and I am having an issue with device names coming up blank.  Anyone else out there experiencing the same with the Nighthawk app?  I put in a call to Netgear support and actually spoke to someone who then transferred me to the "expert" support team.  I waited for 1 hr 15 min and then the call was dropped.  Go figure!
My router:  C7000v2.
Internet:  xfinity
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi nldl8485,
    May you send me a private message with your case number(s) and email address. I'd like to assist with our support team following up with you.
    Christian
        Christian_R
        nldl8485,
        Thanks for the info. We recently release version 2.8.2.0 for the Nighthawk app (iOS). May you reinstall and let me know if your issue persists.
        Christian
  • Same here! Android app version 2.9.6.1513, Speed Test and Remote Management tiles missing! They were there yesterday before I updated...
  • I’m having same issue. Updated app to current app. Can’t speed test. Remote login.
  • I am also missing the speed test tile, has this been removed with the latest update?
    • michaelkenward's avatar
      michaelkenward
      No.
      But it depends on what you are talking about. The Android app?
      What device? A Netgear router of some sort? What firmware?
      • nighthawkuser42's avatar
        nighthawkuser42
        Initiate
        Using iOS Netgear Nighthawk app version 2.21.0.332.  Same issue, the Speed Test tile is not visible or accessible with the latest update.
        Only see:
        - Device Manager
        - WiFi Settings
        - Guest WiFi
        - Traffic Meter
        Hardware Version: XR500
        Router Firmware Version: V2.3.2.134
