mikeanello's avatar
mikeanello
Nighthawk App won't connect to router
All of a sudden starting yesterday my nighthawk app stopped working and I can no longer access my router. If I connect with 192.168.1.1 from a web browser I can log in as admin and everything works. The app timesout and prompts from a password for admin. I type in the correct admin password and it fails to log in. Model is R7960P purchased at Costco.
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello Mike,
    May you try reinstalling the Nighthawk app and provide us with the current firmware version your router is on.
    Thanks,
    Christian
    • mikeanello's avatar
      mikeanello
      I already uninstalled the app on my android phone and re-installed it. I also loaded the app on my ipad and have the same result. Web URL access works from Chrome, the APP does not. It worked fine for the first 2 months or so. The router is up to date. The version is: V1.4.1.50_1.3.10
        Christian_R
        Hi Mike,
        Thanks for confirming. I would recommend performing a factory reset and running through the setup assistant again. Use the Nighthawk app to run through the setup assistant.
        Christian
