tedco
Jan 25, 2021Aspirant
Nighthawk App
Having just purchased a AC2600 Nighthawk X4S VDSL/ADSL Modem Router Model D7800, the installation routine mention to download app for remotely access the router. I downloaded and installed just to f...
- Jan 29, 2021
tedco wrote:
I can't help thinking that you are not very impressed with NetGear :-)
Not at all, you should read what other people say. I just have a realistic expectation of what Netgear does.
tedco wrote:
As I also have a couple of Arlo Pro 3, I thought NetGear would be the best, as both product are from the same company.
Nope. Arlo and Netgear parted company a couple of years ago.
tedco wrote:
Besides, my ISP did support the D7800 router, but none of TP Links products.
Well done. Usually suggest that people check compatibility with their ISP.
For DSL, I also like to recommend separate modems and routers. Unfortunately, Netear and other brands seem to have abandoned the modem only market, possibly because ISPs like to detect people from buying their own stuff.
michaelkenward
Jan 27, 2021Guru - Experienced User
I downloaded and installed just to find that the "wifi router not supported", and "this app does not support your router model".
What did you read that told you to "download app for remotely access the route"? The manual?
Netgear strikes again. Hopeless lack of communication.
As you will see from this, it is the Genie App that supports the D7800
Which products support the NETGEAR Nighthawk app? | Answer | NETGEAR Support
The Nighthawk app requires new firmware. Netgear hasn't thought to update it for your modem/router.
That's actually good news, because the Nighthawk app is a dumbed down version that wipes out some useful features.
You don't say which device you have, iOS or Android, so it is down to you to find the Netgear Genie.
- tedcoJan 27, 2021Aspirant
Hi Michael,
Thank you for your reply - at the end of configuring the router, there was a link, but of course I can't find it now.
I am using a AC2600 Nighthawk X4S VDSL/ADSL Modem Router Model D7800 with Windows 10 Home.
I will be using the Genie App as you mentioned, although NetGear does not support this any more.
Thank you again
- michaelkenwardJan 28, 2021Guru - Experienced User
tedco wrote:I will be using the Genie App as you mentioned, although NetGear does not support this any more.
Netgear has never provided much in the way of "support" for its apps. It just lobs them out into the wild and leaves users to get on with it.
When it comes to the desktop genie, there are rare updates, although that too is essentially abandonware.
- tedcoJan 28, 2021Aspirant
Hi Michael,
Thank you,
When researching for a replacemenet router for my aging TG789v2, I was torn between TP Link and Netgear.
Kind Regards
