Lcadet's avatar
Lcadet
Nighthawk app
I have the XR500 and EX7700 the app on IOS has never worked properly. Here are the issues I found an hope you can help me.
XR500- cannot see devices connected.
This device is on the latest firmware and was factory reset once before and still nothing.
EX7700- devices show up but I cannot disconnect them from the network or do anything at all other then view the Ip and MAC address.
Is this only on my devices. I have tried on IPhone XS and iPad Pro. Yes all on the latest IOS. And still nothing. Any help out there???
  • plemans's avatar
    Is it only on the app?
    Are you able to it through the browser?
    • Lcadet's avatar
      Lcadet
      On the dumaos web interface everything is ok. I can see all devices and can stop, delete etc. as needed. Other than change the Wi-Fi passwords, enable guess wi-if and test the internet speed there is 0 functionality on the app.
      • plemans's avatar
        you could try uninstalling/reinstalling the app. But I wouldn't worry about it to much if the browser is working fine
