Jarga5
Mar 25, 2026Guide
Nighthawk App
I spoke to Netgear on the phone and they told me is was some new app update they would be rolling out soon. That was a year ago, so I cant get a clear answer from them.
Jarga5
Apr 06, 2026Guide
There is a Nighthawk app UI for Device Manager that a lot of others seem to have that includes dark mode, groups devices by WiFi band, has toggles for each device, and is much cleaner than my device view. In addition, my current UI shows every device that was ever connected (119 devices). I only have 24 currently connected.
I actually found another post here on this exact topic. Here is the LINK for that.
Nighthawk firmware version: 2.52.0.42
iOS: 26.4
I want my iOS app to show this newer UI shown in the link above. With Netgear, I discussed how to get my app to show this version of the UI. They told me it would be rolled out with a software update. This was about a year ago and nothing has changed.
Apr 06, 2026Guru - Experienced User
And do you have any SPC or Armor enabled in the NH app?
And to confirm you have a MR60 MESH Router?
I have RS600 online and will check this later today.
- Jarga5Apr 06, 2026Guide
No SPC, Armor is enabled, and yes confirming I have a MR60 router.
- FURRYe38Apr 07, 2026Guru - Experienced User
Looks like the darker theme may not be in the app anymore or presently:
Can only sort by the 3 options here:
- CrimpOnApr 07, 2026Guru - Experienced User
Thanks for taking the time to investigate this. Sort of leaves the impression that the programming teams for Apple and Android apps are separate. Looks like Sort By Status means "Allowed" vs. "Blocked"?
