Jarga5
Mar 25, 2026Guide
Nighthawk App
I spoke to Netgear on the phone and they told me is was some new app update they would be rolling out soon. That was a year ago, so I cant get a clear answer from them.
Apr 06, 2026Guru - Experienced User
And do you have any SPC or Armor enabled in the NH app?
And to confirm you have a MR60 MESH Router?
I have RS600 online and will check this later today.
Jarga5
Apr 06, 2026Guide
No SPC, Armor is enabled, and yes confirming I have a MR60 router.
- FURRYe38Apr 07, 2026Guru - Experienced User
Looks like the darker theme may not be in the app anymore or presently:
Can only sort by the 3 options here:
- CrimpOnApr 07, 2026Guru - Experienced User
Thanks for taking the time to investigate this. Sort of leaves the impression that the programming teams for Apple and Android apps are separate. Looks like Sort By Status means "Allowed" vs. "Blocked"?
- Jarga5Apr 07, 2026Guide
Status seems to mean "connected "vs "not connected". I show 20 "green dot/connected " devices on the top of the list, and +100 unused devices below that that can only be cleared one by one.
Interestingly, when sorted by status there is no "Home" profile. When sorted by A-Z or Z-A, there is a "Home" profile. Not sure how relevant that is though.
All I'm trying to do is get Netgear to push the better UI software to iOS consistently. Its shown up on my phone before but never for long. Maybe 3 days a year I have the good UI.
