ADS42
Aug 10, 2025Aspirant
Nighthawk IOS app Blank screen since a few day, app not usable
 Hi,  my iphone app (Iphone 7 plus, last version of firmware of my MR60, and last version of the app).  I have removed the app, installed again and same white screen after a few seconds. I can acces t...
- Aug 22, 2025It seems to work with another iPhone SE2020 with IOS 18 onboard so for me the IOS15 is no longer supported.
Aug 11, 2025Guru - Experienced User
I recommend that you submit a bug report when you hit the white screen:
How do I submit a bug report or logs from the Nighthawk or Orbi app? | NETGEAR Communities
Also your using a older model phone. Happen to have a friend or family member that has a newer phone to test this with?
ADS42
Aug 12, 2025Aspirant
Thanks for the bug report tip, I have sent a bug report and will try to use an iPhone SE 2020 also tonight to see if it works
