willyferg
Aug 02, 2025Follower
Nighthawk IOS app is broken
Nighthawk IOS app is broken. Just goes white screen
Aug 03, 2025Guru - Experienced User
What model Apple device do you have?
What iOS is loaded?
What NG model router do you have?
- BobWigg761Aug 03, 2025Tutor
Android 11
Motorola 5g AceNighthawk X6 8000
- FURRYe38Aug 03, 2025Guru - Experienced User
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR CommunitiesSo where in the launch of the NH app do you only see white on the screen?
Are you able to see the log in screen at all?
