willyferg
Aug 02, 2025Follower
Nighthawk IOS app is broken
Nighthawk IOS app is broken. Just goes white screen
BobWigg761
Aug 03, 2025Tutor
Android 11
Motorola 5g Ace
Nighthawk X6 8000
Aug 03, 2025Guru - Experienced User
Be sure to disable any MAC Address randomizers on phones and pads while at home:
NETGEAR Mobile Applications and Android/Apple/Windows Devices FAQ | NETGEAR Communities
So where in the launch of the NH app do you only see white on the screen?
Are you able to see the log in screen at all?
