Wisguy's avatar
Wisguy
Nighthawk
Setting device to no Wi-Fi access does not stay set. When I select that setting for a device and check it the next day the status changed to allow access.
  • michaelkenward's avatar
    michaelkenward
    What Netgear device are we talking about here? There are dozens of "Nighthawks".
    What do you mean by "no Wi-Fi access"? You turned off the wifi? Blocking a device? Something else?
    Start by explaining what you want to achieve and someone might come up with an idea.
    • Wisguy's avatar
      Wisguy
      App 2.4.24.1
      Firmware 1.0.9.88
      In the app I want to temporarily block Wi-Fi access using the nighthawk app. I set the device to no access and check the app the next day and the status reversed itself thus allowing Wi-Fi access.
        michaelkenward
        Wisguy wrote:
        Firmware 1.0.9.88
        Not quite the latest.
        Block access to what? An attached device of some sort?
