miguelr0man's avatar
miguelr0man
NyteHawk r7000
I recently reset my router, now i am able to connect using the app but only locally. How can I update so that i can connect from anywhere as i was able to before
  • FURRYe38's avatar
    Enable Anywhere Access under Settings on the NH app.
    • miguelr0man's avatar
      miguelr0man
      It is setup which is why I don't understand why it's not working
      • michaelkenward's avatar
        michaelkenward
        Your messages are thin on useful detail.
        What happens when you try to use Remote Access?
        Which app are you using? Android? iOS?
