R6350
Jan 11, 2022Follower
only power light is on R6350
Hello,
Only the power light is blinking on the top of the Router. It's connected to the modem, but I can't get it to show up as a device on the app.
1 Reply
R6350 wrote:
Hello,
A few points.
- Your subject says R6350 but it says C6300 in the footer. Which is it?
- You have posted in the Nighthawk App section. That isn't the place for either of these devices.
A blinking power light is a sign of broken firmware. That isn't something easily fixed.
First try this:
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
There is more severe, recovery reset, that you could try:
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routersor
General WiFi Routers (Non-Nighthawk & Non-Orbi) - NETGEAR Communities
It depends on which device you actually own.
