News71's avatar
News71
Tutor
Jun 19, 2017
Orbi RBR50 genie app will not allow me to enable guest access
Genie app says that the router doesn't support guest access.
I have enabled guest access on the router.
Satellite RBS50
Firmware v 1.10.1.2
IOS version of app.
  • Just updated the router and satellite to the latest firmware v1.11.0.20
    Guest Network is enabled
    SSID broadcast is enabled
    WPA2-PSK is enabled.
    Still, the genie app says the router doesn't support guest WiFi.
    Does anyone know how to fix this?
    • Mike734's avatar
      Mike734
      Star
      I have the same problem. Technical support for Netgear seems to be very very limited and understaffed. I can enable the guest network through the web browser interface but not the genie app. The Orbi app is useless also.
      What at I need is a way to schedule my guest network to shut down every day at a prescribed time. Parental controls are not a solution. Come on Netgear, listen to your customers and get it together. This in not a problem with Lynksis.
  • I agree Mike. The router itself is very good, but the app and genie app are poor. Netgear needs to make some major improvements to both. ASUS has a much bet app.
