LHL711's avatar
LHL711
Parental bypass controls - R7000
I have enabled my parental controls, downloaded the Genie app and change settings to so my devices will bypass the controls.  Even with my devices using the bypass, I am still blocked.  Let me give a specific.
I created a blacklist and whitelist in my parental control settings.  I want to block YouTube.  I have downloaded the Genie app, activated the bypass account on specific devices, and still am blocked from YouTube.  I have checked the Network Map on the device in question and on my laptop and can see that the devices in questions have parental controls enabled with the bypass login engaged.
I have read some of the others comments and tried the following:
Deleting and reinstalling Genie
Disabling Parental Controls and Enabling again
Refreshing my settings - Parental Controls, Wireless, and Router Settings
Rebooting my Router
None of these have worked.
I am not a computer novice and have tried to research the comments but to no avail.  What do I need to do in order to have this work properly.  Any suggestions would be helpful.
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi LHL711,
    Please make sure that the DNS settings of the devices are set to be obtained automatically from the router. Also, make sure that when LPC (Live Parental Controls) is enabled that the router's DNS are set to the OpenDNS servers of 208.67.222.222 and 208.67.220.220. If not, you can have them manually set.
    Dexter
    Community Team
    • LHL711's avatar
      LHL711
      My DNS setting were on automatic but I manually changed them to the ones you suggested.  After I did that, my Mac was able to bypass but my phone and iPad was not.  It seemed that my iPad kept logging me out because it made me log in to the genie and do the bypass login every time.
      Also, when I would check my network. Map and click on the device to check status, it would show the bypass login was engaged. Again, that was. It the case for the devices in question.
      I ended up disabling the parental controls until I have more time to play with it.  Any more ideas, thoughts, or comments to help further with this would be greatly appreciated.
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi LHL711,
        1. Manually set the DNS on the devices themselves.
        2. What version of the NETGEAR Genie do you have installed?
        3. Is it only on iOS devices or on Android as well?
        Dexter
        Community Team
