PhillipF
Sep 10, 2017Follower
Parental control not working
I set up the parental Controls on the Open DNS. They worked fine the first day. My teenager found the password and now the parental Controls don't work. I've changed the password, but that has NOT hel...
- Sep 19, 2017
Hi PhillipF,
1. What is the model number and firmware version of the router?
2. We recommend installing the NETGEAR Genie on a device that only you have access to after changing the password.
3. Did you modify the settings via https://netgear.opendns.com/sign_in.php?
4. What device are you using to change the filtering level (PC, Android, iOS)?
Dexter
Community Team
DexterJB
Sep 19, 2017NETGEAR Moderator
Hi PhillipF,
Dexter
Community Team
