MichaelDuffin
Oct 05, 2017Follower
Parental control wont wok with wired connection
Hi, I have set up the parental controls and registered for the free opendns account. All wireless devices are working correctly (blocking sites such as http://www.internetbadguys.com/ & http://ww...
- Oct 17, 2017
Hi MichaelDuffin,
1. What is the firmware version of the router?
2. Please try other filtering levels for the wired devices and check if the issue persists.
3. What version of Genie were you using to configure the settings?
Dexter
Community Team
DexterJB
Oct 17, 2017NETGEAR Moderator
Hi MichaelDuffin,
Dexter
Community Team
DexterJB
Oct 24, 2017NETGEAR Moderator
Hi MichaelDuffin,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
