TitoNYC
Feb 08, 2016Aspirant
Parental controls for individual devices
I can't get parental controls to work on individual devices using the map. If I use the Netgear genie on my PC to change the system-wide filtering to high, blocking works. But if I set it system-wi...
TitoNYC
I need to clarify and correct... I can block all sites if I go to "dashboard.opendns.com" and set blocking there. But can not do it using the genie or at a device level.
DexterJB
Feb 09, 2016NETGEAR Moderator
Hi @TitoNYC,
1. What is the model number and firmware version of your router?
2.What version of NETGEAR Genie do you have installed?
3. Have you tried configuring the per device filtering level on another device (another computer, smartphone, tablet)?
Dexter
Community Team
