TitoNYC
Feb 08, 2016Aspirant
Parental controls for individual devices
I can't get parental controls to work on individual devices using the map. If I use the Netgear genie on my PC to change the system-wide filtering to high, blocking works. But if I set it system-wi...
DexterJB
Feb 09, 2016NETGEAR Moderator
Hi @TitoNYC,
1. What is the model number and firmware version of your router?
2.What version of NETGEAR Genie do you have installed?
3. Have you tried configuring the per device filtering level on another device (another computer, smartphone, tablet)?
Dexter
Community Team
TitoNYC
Feb 09, 2016Aspirant
Thanks Dexter for the quick reply.
1. Nighthawk R6700, Firmware Version V1.0.0.24_10.0.18
2. Netgear Genie version 2.4.20
3. Yes, I've tried setting the desktop where Genie is installed and multiple ios devices in more strict settings.
Dexter, maybe I've done something wrong in mixing the settings for Live Parental Controls, Netgear parental controls and OpenDNS? I've been trying to get this work for a while and have tried to follow instructions in any article I can find to see if I can get it to work!
Maybe this is why I can block sites network-wide from dashboard.opendns.com but not from netgear.opendns.com?
Thanks for your help.
- DexterJBFeb 09, 2016NETGEAR Moderator
Hi @TitoNYC,
It is possible that your existing OpenDNS account settings are conflicting with the LPC settings. LPC should be managed through the NETGEAR Genie app/program or through https://netgear.opendns.com/sign_in.php.
Dexter
Community Team
- TitoNYCFeb 09, 2016Aspirant
Yes, I have that set to moderate but it has no effect. What do I neet to set as IPs or DNS to make this work? Or what else might I be doing wrong? Thanks.
- DexterJBFeb 10, 2016NETGEAR Moderator
Hi @TitoNYC,
Are you using the same logins for your OpenDNS account and the LPC settings with NETGEAR Genie?
Dexter
Community Team
