Jamie_M
Jun 09, 2017Guide
Parental Controls, Genie, and
I discovered that my Parental Controls, which had previously been set and were working just fine, had somehow become disabled. So I fired up Netgear Genie on my Mac and hit the Parental Controls Tab....
DexterJB
Jun 22, 2017NETGEAR Moderator
Hi Jamie_M,
1. Please try using another device (Android, iOS, another computer).
2. Have you tried resetting the router?
Dexter
Community Team
Jamie_M
Jun 23, 2017Guide
Thank you for your reply Dexter. As mentioned in another, similar thread (https://community.netgear.com/t5/Genie/Parental-Controls-Checking-Router-Firmware/m-p/1305877#M6143), yes, I did try resetting the router to factory defaults, which had no effect. And yes, the issue persists whether I use my Mac, iPhone, or iPad—it simply will not work.
