marekproc
Sep 17, 2016Aspirant
Parental controls not working on any of my two NETGEAR routers
Hello, I have setup Parental Controls on my two routers (Nighthawk R7800 and WNDR4300). In https://netgear.opendns.com I can see the two devices. Even if I set the filtering level to "high" and i...
- Oct 30, 2016
Hi Norvell1984,
You may refer to the links below on how to setup and configure LPC (Live Parental Controls).
http://kb.netgear.com/app/answers/detail/a_id/25687
Once you have the device/s connected, you can set the filtering level for each device. You may find the link below helpful.
http://kb.netgear.com/app/answers/detail/a_id/29913
Dexter
Community Team
DexterJB
Sep 19, 2016NETGEAR Moderator
Hi marekproc,
1. Do you have both devices as routers or is one setup as an AP?
2. What are the firmware versions of each device?
3. Are the DNS values on the device UI's set to the OpenDNS values of 208.67.222.222 and 208.67.220.220?
4. Have you tried setting the filtering level using the NETGEAR Genie app/program on your devices?
5. There are instances that the filtering does not take effect immediately right after setup since it will need to sync up with the OpenDNS servers.
Dexter
Community Team
Norvell1984
Oct 28, 2016Aspirant
My nightHawk ac1900 r7000
Make sure the device UI's are set to the OpenDNS values of 208.67.222.222 and 208.67.220.220.....
How do I change them to ththat if they are not? I created an OpenDNS through Netgear's Genieapp and nothing is happening.
Does this feature work through the DSL or does each computer have to be set up individually?
I would like to save the hassle of arguing with my little ones about why I am blocking porn sites and such even if they do not go to them.
- DexterJBOct 30, 2016NETGEAR Moderator
Hi Norvell1984,
Dexter
Community Team
