marekproc
Sep 17, 2016Aspirant
Parental controls not working on any of my two NETGEAR routers
Hello, I have setup Parental Controls on my two routers (Nighthawk R7800 and WNDR4300). In https://netgear.opendns.com I can see the two devices. Even if I set the filtering level to "high" and i...
- Oct 30, 2016
Hi Norvell1984,
You may refer to the links below on how to setup and configure LPC (Live Parental Controls).
http://kb.netgear.com/app/answers/detail/a_id/25687
Once you have the device/s connected, you can set the filtering level for each device. You may find the link below helpful.
http://kb.netgear.com/app/answers/detail/a_id/29913
Dexter
Community Team
Norvell1984
Oct 28, 2016Aspirant
My nightHawk ac1900 r7000
Make sure the device UI's are set to the OpenDNS values of 208.67.222.222 and 208.67.220.220.....
How do I change them to ththat if they are not? I created an OpenDNS through Netgear's Genieapp and nothing is happening.
Does this feature work through the DSL or does each computer have to be set up individually?
I would like to save the hassle of arguing with my little ones about why I am blocking porn sites and such even if they do not go to them.
DexterJB
Oct 30, 2016NETGEAR Moderator
Hi Norvell1984,
Dexter
Community Team
