gworley
Sep 20, 2015Aspirant
Parental Controls not working properly
I manage 2 sites -- home and a homeless shelter. Both sites I have installed Netgear routers. At the homeless shelter I have a WNR2000v3 installed and it supports Parental Control. At home I have ...
cricket16
Apr 09, 2016Aspirant
Purchased a Nighthawk x4s AC2600 yesterday, turned on parental controls, checked it and it literally allows anything and everything through even on the highest setting.
Netgear has virtually zero customer care, and now I find out that Netgear have known of this harmful failure since at least January 2016 September 2015 and done ZERO about it! After reading more posts where its contributors blame the user, or the user's software and/or hardware when they must know it is their software: the only word to describe Netgear's behaviour is deceptive.
I have updated the firmware, double checked the settings and it is seriously disturbing that a so-called major industry player continues to ship products knowing that their advertising is false and mis-leading and further, that customers relying on these promises can inadvertently be exposing their children to major harm.
Frankly, this is an unconscionable and deliberate failure by Netgear to fix its software and I will be raising this with the authorities and media on Monday morning.
DexterJB
Apr 12, 2016NETGEAR Moderator
Hi @cricket16,
1. What is the firmware version of the router?
2. What version of NETGEAR Genie do you have installed?
3. Are all devices affected (wired and wireless)?
4. What are the DNS values on the device UI?
5. Have you tried changing the filtering level using other devices (smartphone, tablet, other computer)?
Dexter
Community Team
- mrekimfApr 21, 2016Apprentice
How do you set these DNS values? I see replys to change or set the DNS values but not how? I windows 8.1, and setting parental controls on devices but not working.
My router firmware is
V1.0.4.30_1.1.67 netgear genie version is 2.4.20
thank you
- DexterJBApr 24, 2016NETGEAR Moderator
Hi @mrekimf,
1. What is the model number of your router?
2. Please download and install the latest version (2.4.26) from the website liked below.
http://netgear.com/home/discover/apps/genie.aspx
3. Have you tried setting up Parental Controls on another device (another computer, smartphone, tablet)?
4. You can check and set the DNS values by accessing the router's UI. You may refer to the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/980
5. Once you have accessed the router's UI, you can check/change the DNS values by going to Advanced > Setup > Internet Setup > Domain Name Server (DNS) Address. Please make sure the values are set to 208.67.222.222 and 208.67.220.220.
Dexter
Community Team
