gworley
Sep 20, 2015Aspirant
Parental Controls not working properly
I manage 2 sites -- home and a homeless shelter. Both sites I have installed Netgear routers. At the homeless shelter I have a WNR2000v3 installed and it supports Parental Control. At home I have ...
DexterJB
Sep 21, 2015NETGEAR Moderator
Hi gworley,
May I know if you are using the Insider Preview build of Windows 10?
You may try setting a static DNS for your laptop and use the OpenDNS one which are 208.67.222.222 and 208.67.220.220 and see if the Parental Controls work.
Dexter
Community Team
- gworleySep 21, 2015Aspirant
- DexterJBSep 22, 2015NETGEAR Moderator
Hi gworley,
You may uninstall and re-install it just the way you would with other programs, through the Control Panel.
Dexter
Community Team
- gworleySep 25, 2015Aspirant
I have done that many of times and reinstalled with the same results. Cannot get to Parental Controls throught Genie. Netgear sent me a link to a stand-a-lone product that works. The last reinstalled made things worst -- on my home router I could get to them after about 4 or 5 retries and now I cannot get to Parental Controls on the home router. Never could on the router at the homeless shelter were I work. Other PC's work and other devices like Android work. Plus this PC doesn't get blocked on adult sites at the homeless shelter while the ones where Netgear Genie works get blocked trying to go to the Adult sites. Network settings are the same -- DHCP assigned IP and DNS assigned to router -- DNS on the router points to OpenDNS servers. There has to be some setting that isn't getting uninstalled on this laptop that is the reason I asked how to do a clean install. BTW: Going through the Control Pannel and uninstalling then reinstalling is not considered a Clean Install as there is always something left on the machine -- mostly registry settings and user profile settings.
George
MSCE
