gworley
Sep 20, 2015Aspirant
Parental Controls not working properly
I manage 2 sites -- home and a homeless shelter. Both sites I have installed Netgear routers. At the homeless shelter I have a WNR2000v3 installed and it supports Parental Control. At home I have ...
DexterJB
Sep 21, 2015NETGEAR Moderator
Hi gworley,
May I know if you are using the Insider Preview build of Windows 10?
You may try setting a static DNS for your laptop and use the OpenDNS one which are 208.67.222.222 and 208.67.220.220 and see if the Parental Controls work.
Dexter
Community Team
