Roadturn
Feb 23, 2018Tutor
Parental Controls Won't Quit
I get blocked randomly by parental controls on visits to harmless websites. I've turned off parental controls completely. I've even restored the router to factory condtion. But I still get blocked b...
- Feb 23, 2018
The Arris model reports that it's a gateway router as well. Is the modem fully bridged? If not, it should be to allow the NG router to handle internet and NAT traffic. You maybe in a double NAT condition.
Feb 23, 2018Guru - Experienced User
If the modem can't be bridged, you can use the modems DMZ for the IP addresss the NG router gets from the Modem for another solution for this.
