israelisraeli's avatar
May 07, 2016
Passive FTP configitation (VEGN 2610)
I'm trying to set up an FTP server located at a NAS on my LAN.
Iv'e set port forwording for the data chanel and the passive command chanel (passive range) but it seems that there's still a problem with my configiration.
i can acsses the server using it's local IP inside the LAN (but not by public IP).
her's a link to screenshots of all the relevent configorations on the NAS and on the router
does anyone have an idea of what could go wrong?
thanks for the help!
    • israelisraeli's avatar
      israelisraeli
      yes, with netgear's pre-made setting (which are simply TCP 20-21). you can the screenoshots in the original post
      • TheEther's avatar
        TheEther
        Guru
        If your public IP really public?  Does it start with 192.168.x.x, 172.16.x.x, 10.x.x.x or 100.x.x.x?
