Danest48's avatar
Danest48
Printing using Netgear ReadySHARE Print function is not working.
I am unable to actually print from my laptop using the ReadySHARE Print funtion in the Genie.
I have followed the instructions and have the USB Control installed on my Windows 10 laptop and my Windows 7 desktop. The USB printer on my desktop is a Brother HL-1440.
(I have a HP Officejet 6740 wireless connection that is working perfectly using the router.)
The Brother printer is visible in the Devices and Printers section of my laptop and goes through the print selection steps but then nothing happens.
Any tips on how to make the connection using ReadySHARE Print?
Thanks!
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Danest48,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
