kingbone99's avatar
kingbone99
Follower
Mar 23, 2016
Q r code
Why is a Q our code required for my wireless settings button ??
  • DexterJB's avatar
    DexterJB
    Nov 02, 2016
    Hi Shhhhdontsayit,
    Yes, that can be one use case scenario. You can also use your own mobile devices that can scan the QR code. It is basically a way to see the wireless settings (WiFI name and WiFi password) of your network.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi @kingbone99,
    Scanning the QR code found on the Wireless Settings tab of the NETGEAR Genie program allows you to connect a wireless device (i.e. smartphone) to the network since it will provide the SSID and the passphrase. The device should have a QR code scanner app.
    Dexter
    Community Team
  • I still don't understand. I have the mobile genie app on my phone. What would I scan a Q code for? A guest phone?
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Shhhhdontsayit,
      Dexter
      Community Team
