r7000_nooby
Jun 14, 2018Aspirant
R7000 Nighthawk Readycloud setup won’t allow read/write.
Windows 10/Windows 7/Linux, home network only, with latest firmware as of 06/13/2018
I have set up Readycloud, have a ReadyCloud account, and am able to login in to it from a browser.
After l...
michaelkenward
Jun 18, 2018Guru - Experienced User
r7000_nooby wrote:
Sorry no offense meant, I am OLD, I AM curmudgeonly, and a ROYAL PAIN!
No offence taken, but there is a good chance that I can beat you on the GOG (grumpy old git) front. I am too old to be a baby boomer.
On Windows drivers and your USB box, you often don't have to install them. They are built into Windows, but not, sadly, into the "operating system" that Netgear uses to run routers. That is why ReadySHARE is limited in the drives it USB supports.
As a Linux user, you will surely have encountered devices that you cannot get to work. We see those "where can I get Unix" drivers here from time to time.
r7000_nooby
Jun 18, 2018Aspirant
what is a baby boomer? I have siblings older than baby boomers.
my external USB is not on the list for the R7000, so why does it work in Windows network, and Linux as well?
so far I have not had a device ‘not’ recognized yet by Linux. Only a multi-function that Canon doesn’t make Linux drivers for. I even sent them a picture if the box stating ‘drivers for Windows, MAC, and Linux’. The scanner works, the fax works, but no printer drivers.
But> not your problem.
Probaby should end this thread now. Getting past it’s intended purpose.
