akella
Sep 01, 2020Initiate
R7400 parental controls
I am unable to see the parental control button on the Nighthawk app or on the routerlogin using my web. I am also unable to block websites like roblox and discord using the block sites function. This netgear has been so confusing. Paid so much for this and theres no support on this. Does not even have parental controls?
1 Reply
They removed access to parental controls from the Nighthawk app. They'd rather you used the paid for Circle alternative.
I see no sign in the manual that the R7400 supports parental controls. Did they add it with new firmware?
If so, you can still use a desktop and the Desktop genie to do this.
Or you can use your account to login to opendns.
That should work on your mobile.
How do I set up Live Parental Controls on my Nighthawk router? | Answer | NETGEAR Support
