Toonaway
Dec 30, 2016Guide
R7800 - Unable to login to OpenDNS / Parental Controls
I have followed the various support instructions but have failed to get Genie to log into OpenDNS. I receive the following: There was an error signing in, please make sure you're connected to the I...
IndianaMark
Feb 02, 2017Aspirant
I rolled firmware back to version 18. Problem solved. Bug in current version of Netgear firmware.
- BigJackFeb 02, 2017Aspirant
Many thanks for your answer! :smileyhappy:
I just checked the download site: https://www.netgear.com/support/product/R7800.aspx#Firmware Version 1.0.1.30
and there is no version 18. :smileysad:
I found following versions:
1.0.2.12
1.0.2.04
1.0.1.30
older
- TechHeroApr 27, 2017Initiate
indianaMark - "I rolled firmware back to version 18. Problem solved. Bug in current version of Netgear firmware."
Can confirm, Firmware 1.0.1.18 works for the R6400. Thanks! I've been trying to solve this problem for HOURS.- MontyTheLab2Apr 27, 2017Guide
Will try it...thanks for the tip
- IndianaMarkApr 27, 2017Aspirant
I tried the upgrade recently to 1.0.1.22 with Netgear Genie version 2.4.38 on my R6400 No success. It's so hard to understand why Netgear is not facing this head on and fixing this issue. I have read on other forums that they will soon have a new version of Netgear Genie released. I hope this solves this issue. This has sure given Netgear a black eye. Unacceptable for a company with their resources.
