Toonaway
Dec 30, 2016Guide
R7800 - Unable to login to OpenDNS / Parental Controls
I have followed the various support instructions but have failed to get Genie to log into OpenDNS. I receive the following: There was an error signing in, please make sure you're connected to the I...
IndianaMark
Feb 02, 2017Aspirant
I rolled firmware back to version 18. Problem solved. Bug in current version of Netgear firmware.
BigJack
Many thanks for your answer! :smileyhappy:
I just checked the download site: https://www.netgear.com/support/product/R7800.aspx#Firmware Version 1.0.1.30
and there is no version 18. :smileysad:
I found following versions:
1.0.2.12
1.0.2.04
1.0.1.30
older
